More DataAssist Errors Locally
Thread begun 8/04/2009 5:11 pm by reneas.email303886 | Last modified 8/06/2009 2:16 pm by Jason Byrnes | 7691 views | 9 replies |
reneas.email303886
Here is the error I receive after attempting to post a record to my db using this page locally:
resume_Insert.php
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'References FROM resume WHERE ID = -1 OR ( -1= -1 AND ID= 3)' at line 1
but it adds the record just doesn't show me resume_Detail.php ...I just get the error listed above. Why the error and how do I correct it?
Renee'
The error is occurring because one of the columns in your table is named using the MySQL Reserved Word "references".
There are some words that should not be used when naming Columns, tables or other objects in you database because they are reserved as function calls. A full list of reserved words can be found here:
reserved-words.html
reneas.email303886
Error Still Exists?
Jason:
Okay...I renamed the Column in my db to Personal References and it still generates same error. Going to call in Personal Recommendations or something other than references. Fingers crossed that it works.
R
Nope that did not work either. Renamed my column Personal Referrals and that still generated the error?
R
Database column names should not contain a space.
Try naming the column "PersonalReferrals" instead.
After changing the name, you will need to delete the pages created by the DataAssist wizard and recreate them.
reneas.email303886
Error Still Exists?
Jason:
Okay none of my columns have spaces and I am not using the word references? Still getting the error:( I took a screenshot of my table for your review but not sure where to send or attach it in the forum.
Renea
reneas.email303886
Still Does Not Work After Column Renamed, Etc.
Jason:
I renamed the column to PersonalReferrals and it still does not work! Really getting frustrated. The resume_Insert.php page adds a record to the db. Currently there are 10 records;however, when resume_Insert.php attempts to redirect to resume_Detail.php that is when the error occurs. Appreciate anyone's help on getting this error resolved. Thanks!
Renee'
Jason:
Okay it seems to be only the resume_Detail.php page, as the resume_Results.php works and when I update a record from that page, which loads the resume_Update.php page with record I selected it updates the record just fine. The resume_Delete.php page works fine as well. So the only page that seems to be generating the MySQL error is the resume_Detail.php page...Hope this provides some insight so I can get this issue resolved today. Thanks!
Renee'
Support:
Okay folks thru problem solving I compared the code from both the resume_Update.php and resume_Detail.php pages. The detail page was generating the MySQL error and determined that this bit of code created by DataAssist was causing the problem, see code below:
I removed that code and now I am able to view the details of each record in my database. This was very frustrating, as I purchased DataAssist to help me develop applications for my clients quickly without a huge learning curve as advertised on your site and I have to say that bugs like this in your code cost me over day in development time. I would like an explanation. Thanks!
Renee'
The code:
is not a bug.
It is in place to work around a problem in PHP where the session contents are not available on page load, it should not cause a MySQL Error.
Perhaps it would help us debug the problem if you could provide the exact text of the Error, I dont believe it would have been the same as the origianl error you reported if you had renamed the column.
Along with the error, it would help if you could compress a copy of the resume_Detail.php page before it was changed into a zip file and attach it to your replay so we could the code generating the error.
reneas.email303886
Still Problem w/code in tact
  The code:
is not a bug.
Jason:
In despair I resorted to rebuilding the table and the pages. Now I can insert records via resume_Insert.php and see them via resume_Results.php; however, I still receive an error on the detail page resume_Detail.php like so:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'References FROM resume WHERE ID = -1 OR ( -1= -1 AND ID= 5)' at line 1
I have attached a copy of the resume_Detail.php page in zip format for your review...Pls Jason I have already lost 2 days on this project because I cannot get the application to work.
Best,
Renee'
it is not possible for the page you sent to generate to generate that error.
I have started a support ticket for you so we can look into the problem, please respond by logging into your support history at:
supporthistory.php?
In debugging the problem, we noticed that the URL being used:
resume_Insert.php
did not match the location of the pages:
c:\wamp\www\mudcheck
When we changed the URL to match the location of the files:
resume_Insert.php
The page functioned correctly.
In the Site Definition, we saw that the Local Files where being created at:
but the site definition was set to:
c:\wamp\www\
and the URL prefix was set to:
localhost/
We changed those to:
and:
mudcheck/
