Datepicker - Right arrow missing
Thread begun 7/27/2012 7:49 am by John Langer | Last modified 8/03/2012 1:54 am by John Langer | 8655 views | 9 replies |
John LangerBeta Tester
Just used datepicker from Data Bridge (1.0.6) and used the redmond theme. The right arrow is missing as per attached image.
Any thoughts?
I am not able to reproduce the problem. adding a datepicker using the redmond theme, the right arrow is showing correctly for me, make sure that you have uploaded the entire webassist/datepicker folder to your site.
inside that folder will be a subfolder for the date picker on your page, it will start with the same name as your page, the date picker images including the right arrow are in the images folder under that.
Yes it all seems to be there Jason. I actually set it up firstly on my PC / testing server so no files needed to be uploaded anywhere.
I've also set this up on three pages and they are all the same (image missing (or not showing)).
Strange!
So, it sounds like you are using Windows as the OS? What version? 32 or 64 bit?
Also what version of Dreamweaver?
Windows 7
Dreamweaver CS6
64bit (sorry)
hmmm, I'm not sure what is going wrong, can you post a link where i could see this to troubleshoot.
Hi Jason,
Many thanks for the reply. Here is a link to one of the pages
events_results.php
You'll see the date field underneath the map on the right hand side.
i cant see why it is not working on your layout, and I'm not able to reproduce the problem, but i think i have a workaround for you.
in the webassist/datepicker/events_results_datepicker_4/jquery-ui.css file,
edit:
/* states and images */
.ui-icon { display: block; text-indent: -99999px; overflow: hidden; background-repeat: no-repeat; }
.ui-icon { display: block; text-indent: 99999px; overflow: hidden; background-repeat: no-repeat; }
Thanks Jason, That did it.
