Data Assist server error
Thread begun 8/04/2009 11:14 am by cherylrusche378937 | Last modified 8/06/2009 12:38 pm by Eric Mittman | 3985 views | 3 replies |
cherylrusche378937
teams_RegistrationTest.php
I am trying to get this registration page to work using Data Assist.
The team names need to be unique so I want to post to a table called team_names. Then
I use the repeat Selection to post to the teams table and move the team_names id to the nameid in the teams table.
Everytime set up the Manage Relational Table information, I get a Internal Server Error message. I am using a Mac with Firefox.
I'm not a php programmer so I don't know what I am doing wrong.
I've been working on this form way too long. The extensions are not working out very well.
The link you gave gives me a 'can't find server' error message.
The manage relational table server behavior should be used only to update an intermediate table. I'm not sure if what you are trying to do is a proper use of this server behavior. Please post back and include some more detail about exactly what you are hoping to accomplish as your end result and the steps you are taking so far.
Please also include some more info about the error message you are getting, exact text helps. With some more info about this and the error you are getting it will be easier to determine what may be going on.
cherylrusche378937
Server Error
I am trying to register teams of five people on a team. Each team of five needs to have a unique team name.
I was trying post the team name once in a team_name table and pass the team id to the team_id.
I created the form using Security Assist, then saw that Data Assist did a Repeat Selection with Relational Tables. I wanted to post the whole team at one time with one teamname. I could do that with one table, but my problem is they will each need to login. I thought the Repeat Selection in Data Assist would let me post all five and add them to separate rows in the table.
I guess I am going at this all wrong.
Since you need to have a unique name for each five members of a team does this mean that each team will only have a max of 5 members? If this is the case then you could do this a few ways. One way would be to have a team table that is separate from the users table. In this team table you can just have an id column, a name column, then a member column.
Doing it this way you would create a new team, then you can insert the users into their table and have an update for the team table that will add in the member for each insert that occurs for the users table. You would be just inserting the id of the newly inserted user into the team table.
