Form Builder issue
Thread begun 7/26/2012 12:03 am by superpac250441 | Last modified 7/28/2012 8:03 am by Miguel | 4572 views | 9 replies |
superpac250441
Form Builder issue
I have just updated to the latest versions of Design extender and Data bridge(installed in that order).
When I open form builder, I get an error message (see attached picture).
Please assist (DW CS6, Windows 7)
Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
superpac250441
Duh! Thanks Jason, sorry to waste your time
superpac250441
Uh oh .... sorry Jason. I deleted the dat file but the problem remains. The error message is still there
I am not able to reproduce the problem.
Try uninstalling Data Bridge, then installing it again.
superpac250441
Already tried that Jason
Do you have a new blank page when starting form builder?
or are you trying to edit an existing form?
Try using Form Builder with a new blank page to help determine of the problem may be related to the page you are adding it to.
if it work on adding form builder to a new blank page, send a copy of the other page you where trying to add it to so I can try to pinpoint the cause.
superpac250441
I have been starting on a blank page - completely blank. However, I have now just discovered that the problem only occurs when I click the formbuilder icon in the webassist icon panel. If i go webassist > forms > insert form, the issue doesn't arise and the formbuilder wizard starts normally. This may explain why you couldn't replicate the issue. I will go ahead and now make a form to see if any further errors occur
Ok, i have recreated the problem from the insert panel and have logged a bug to have it corrected.
Miguel
Have the same issue hope it gets fix soon
