Update page Checkbox
How do I go about adding an update button to and update page ( and insert page for that matter) once I have created pages in databridge?
I'm not sure I understand the question.
The results page created by the Data Assist wizard will include the update and insert buttons.
I need to know how I add a checkbox to my update and insert pages that will allow my user to check and uncheck the box. I have field that will be listing a job position as New/Urgent. When it is checked ( with a tinyint value of "1") it will show up in the New/Urgent section of the site and when unchecked it will show up only in the general jobs listings on the site.
Right now I have been changing the text input fields into a checkbox with the same value info but it does nothing when I try to update the data or even when I check the field on the Insert page.
Sorry for the confusion. Hope this makes sense now.
add the checkbox to the insert and update page. set the checked value to 1.
On the insert page, edit the Insert record behavior and bind the position column to the checkbox.
On the update page, edit the update record behavior and bind the position column to the checkbox.
On the update page, you will also need to edit the Update page recordset to include the position column in the select statement.
then select the checkbox in design view, in the property inspector, click the Dynamic Button. for the check if options, click the lightning bolt and select the position column form the recordset, set the equal to option and enter 1.
