Data Bridge Universal Email not sending email with pear
Thread begun 7/23/2012 7:08 am by dvolle228412 | Last modified 7/24/2012 9:36 am by Jason Byrnes | 1226 views | 1 replies |
dvolle228412
I've tried to setup an email using universal email, the problem is that the default is mail, which does not authenticate and the resulting email does go out but since it was sent without authenticating the email is filtered as spam by tons of systems!
For most of my purposes the default mail is useless for this reason.
I've tried to use the SMTP with pear option because it has authentication however it does not work, no error is thrown, but no mail is sent either!
Can you make some suggestions on how to get the pear implementation working?
(I often create sites for non profits that have limited budgets and run on shared servers that don't support automatic pear installs. This makes it necessary to install manually via ftp. One thing that would be really helpful for would be a list of all pear files and file structure that is required for this to work.)
to help troubleshoot, you should make sure the email does not redirect to another page after sending, then add the following code to line 1 to turn on error reporting:
error_reporting
(E_ALL);
and add the following code just before the closing </body> tag to write the session contents to the page:
<pre><?php var_dump($_SESSION); ?></pre>
the session contents will include a section to show whether the message was sent to the SMTP server successfully or not, this will help determine if the problem is your Universal Email settings, or the Pear Mail installation. If it is a problem with the Pear install, you will need to contact the host for help on configuring pear.
one thing that The 2 most common issues I run into with PEAR Mail are:
1) Incorrect path to pear
2) In most cases the From Email address must be the same address used for the username section of authentication.
