Uploaading to live server
Thread began 8/04/2009 12:32 am by bernardkane381926 | Last modified 8/04/2009 2:26 pm by Eric Mittman | 1586 views | 1 replies |
bernardkane381926
Hi
I am using the User registration Pack in a site I have been developing. To test the functionality I have used Wampserver 2 as the local host on my own machine. I am now nearly ready to upload the site to my web hosting company. My question (and I appreciate it is really basic by I am a beginner) is this:
When I ftp the site files to my web hosting server what do I need to change in the connections,MySQL stakes to make it all work? Currently my connection.php file is:
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_localhost = "localhost";
$database_localhost = "admin_bks";
$username_localhost = "deleted for security";
$password_localhost = "deleted for security";
$localhost = mysql_pconnect($hostname_localhost, $username_localhost, $password_localhost) or trigger_error(mysql_error(),E_USER_ERROR);
mysql_select_db("admin_bks");
Any help or a pointer to help would appreciated.
Bernard Kane
To get the database transfered to your live server you will want to export it from your localhost, then import it into the live server. Your host will likely have a gui tool for you to do this like phpMyAdmin or something similar.
Once the db is transfered you will need to update the connection file on the live server. You will need to use the same credentials that you connect to the live database with. If the database is on the same server as the domain then localhost should work, otherwise you will need to use the domain or IP for your database. If this is needed the details should be available from your host.
Once you update the connection with this you will also need to ensure you have the correct username, password and database name referenced. You then just upload this file like any other page in your site, if it has the correct values in it for your live db and you have imported the db on the live server successfully it will work for you.
