Cannot open CSS Menu Writer Manager
Thread begun 8/03/2009 5:18 pm by contact364879 | Last modified 8/04/2009 9:20 am by contact364879 | 3071 views | 2 replies |
contact364879
I am on Vista, using Dreamweaver CS3, running CSS Menu Writer v2.01. When I try to open the Menu Manager I get the following error message:
"While executing onLoad in walm.htm a JavaScript error occurred." I then click the OK button on the error dialog box. This message appears again; I click OK again. I then close the blank Menu Manager window.
I have uninstalled then reinstalled the extension, CSSMenuWriter201.mxp. No difference. I've shut down and restarted my PC. No difference.
Thanks in advance for your help.
Dani Chankhour
Have you tried deleting your winfileCache. Deleting this file from your configuration folder should solve this issue. If the error still occurs after deleting your winFileCache, try renaming your configuration folder.
contact364879
That did the trick. Thanks very much.
