Fast method to mod CSS Spry Tool tips ?
Thread begun 7/05/2012 12:45 pm by Steve | Last modified 7/07/2012 9:29 am by Steve | 2297 views | 3 replies |
Steve
Is there a way to modify the CSS Tool Tips for Spry after these are initially set? Some way to access the dialog that allows the WUSIWYG interface? I can't seem to find this.
Also is Web Assist pushing this Spry method of client side field validation over the validation tool kit methods that show the nice modal window with validation errors?
MikeyT
I believe you simply enter the wizard like you did the first time you created the tooltip. When you do, your current tooltip setting should be reflected in the wizard's preview window. Make your tooltip changes and they should take effect.
Yes, Mike is correct, going to WebAssist -> Validation Tooltips for Spry will re open the wizard and inspect the settings that had been used previously to allow you to make changes.
Steve
Thanks Guys!!
