Why can't I edit my contents
Thread begun 6/29/2012 9:30 am by lr_leal239405 | Last modified 8/14/2012 12:30 pm by Jason Byrnes | 4263 views | 10 replies |
lr_leal239405
When I click on 'Define' next to Contents:Portfolio(custom), it doesn't bring up my menu content. It brings up the default, so I can't edit what I already have unless I go directly to the menu.php file. How come? Is it because I didn't save it with a different name? However, on the 'Define' next to Theme: site menu, it does come up with the theme options I set in place, so I can edit those. I included a snapshot of what I'm talking about.
It looks like you are inserting a new menu, not editing the existing one.
to edit the existing menu, select the menu in design view, and in the property inspector, click the edit button.
NOTE: if you manually edit the menu.php page, the changes wont be displayed in the Menu Writer interface.
gzirfas374932
Can't edit menu contents
I, too, am having a similar problem. I AM in design view, I click the menu, the edit menu button displays, but when I click the edit menu it always opens the Insert Menu....
Screen cap attached
(mac, CS6)
sfj6167
I too am in design view
Nothing shows up, where I can edit and get back into css menu writer.
Also when making a new menu, when I change nothing I can insert a menu.
BUT if I design a menu the screen freeze.
see image
Using latest DW on windows 7
Please advise
regards
bison
sfj6167
Hi Jason
Think I found out why. The errors comes when I try to add a menu to a dw template.
When I add it to a normal php page, it works just find...
but how can I apply a menu to a sw template then ??
best regards
you could add the men to a regular page, then use Framework builder to add it to the template as a plugin.
sfj6167
Please guide me how to do this:
when I try to add plugin to dw template I get this message:
"Before you can launch this interface, you will need to open a PHP page from the current site in Dreamweaver", so I cant make the menu as a plugin.
is it not a little complicated this way.
From my asp days, I could simply include the file in the template.
Please advise how to get a menu into the dw template
regards
Bison
sfj6167
Hi Jason
I have now tried to:
tried creating a menu in dw template in a editable region
tried creating a menu in dw template in a non editable region
both menu works,
BUT
there is NO edit for the menu...so I cant edit the menu.
Please assist and advise.
regards
Bison
