Why so many css style sheets?
Thread begun 8/03/2009 1:18 pm by Brad Lawryk | Last modified 8/03/2009 5:00 pm by Jason Byrnes | 2799 views | 1 replies |
Brad Lawryk
Why does it create a seperate style sheet for every page layout?
If I have 10 layouts and want to change the text color or size, I have to go to every style sheet and change the values. Its really no different than having the styles right in the page. Instead of editing styles on 10 different web pages, you have to edit the styles on 10 different css files.
Brad
Each layout will have different dimensions for the different div elements so will need a separate css style sheet. if they al used the same CSS, they would all be the same layout.
You could create a new style sheet named myStyles.css and use that to overide text color and size. as long as it is the last css file attached to each page, and all of the pages use divs with the same name, the mystyles can be used to override the text color or size on all of the pages that use it.
