I'd like to update an item in the cart (ie., update the cookie)
Thread begun 6/10/2012 10:20 pm by dionysus224892 | Last modified 6/13/2012 11:18 am by Jason Byrnes | 4103 views | 4 replies |
dionysus224892
I have a field called "pricechecked" and I'd like to set it as either "y" or "n" by clicking a button. I know you can update the quantity by the following hidden field :
<input type="hidden" name="ebooks_Quantity_<?php echo $ebooks->DisplayIndex; ?>" value="<?php echo $ebooks->DisplayInfo("Quantity"); ?>" />
How would I do it for pricechecked? I tried the following but it didn't work :
<input type="hidden" name="ebooks_pricechecked_<?php echo $ebooks->DisplayIndex; ?>" value="y" />
Thanks for your help!
-G
that looks like it should work as long a the hidden element is in a cart display and you are clicking the update cart button, that should do the trick.
can you send a copy of the page you are using this on and a link where I can see the problem.
dionysus224892
Hey Jason, thanks for responding quickly (again) :)
Can I send you this info privately?
The process is as follows :
-on login, any saved info in the db is loaded into the cart cookie for the users
-changes made while logged in are made to the cart cookie
-on logout, the cookie is saved to the db
For this particular item, I have a few extra steps.
-on click, the value of pricechecked is set to "yes"
-the action of the form is set to add a variable (the code of the book in question)
-the form is submitted, updating the cart contents/cookie
-after submission the user is sent to pricecheck.php which inserts a new record in a table
-the user returns to the profile page
-on logout, new info saved to db
However this is not happening.
I can send you the details privately. Thanks!
dionysus224892
For the record, I don't know how to send you this info privately!
