Error when trying to generate a Results page
Thread begun 5/29/2012 2:59 am by neo314 | Last modified 6/11/2012 1:33 pm by Patrice | 4995 views | 14 replies |
neo314
When I use the WADB Pages wizard to create a custom preset group of pages, I am getting all of the pages except the results page. The wizard hangs up with a half built pages on the wrong theme and then produces this error:
neo314
Thanks. I do have a results page from the previous design extended version, so this is since the last update.
esmond192961
Data Bridge unable to create data assist pages
Hi there
I am having similar nightmare problems using data bridge to create admin pages in osx with Dreamweaver CS6. Having followed all advice regarding installing DataBridge, Ecart5 and Design Extender, (installed 3 times now after a clean install of the latest OSX and Creative suite 6) but Data Bridge still can't create admin pages.
When trying to create pages with the wizzard, firstly, when trying to add pages, the add elements only works spasmodically and often crashes or goes into a loop saying there is an error. When clicking OK, the error message repeatedly reappears and the only way out is to force quit dreamweaver.
When I do manage to get the pages needed included, the wizzard creates 2 pages then halts part way through the third with a javascript error.
While executing timer in WA_SiteTools_ProgressV2.htm, thefollowing Javascript error(s) occurred:
At line 396 of file 'Mac......Configuration:Floarters:WA_SiteTools_ProgressV2.js":wa_getConfigurationPath is not defined
(screen grab attached)
In desperation, I have tried to use another mac still running CS5.5, but am having similar problems.
There are also similar problems with Framework Builder in CS6, but this does work OK in CS5.5
I have noticed on the Forum that others are having similar problems with DataBridge and that Webassist are working on a fix.
What can I do to get around the problem until Webassist can get these 3 applications udated to be compatable with CS6
neo314
I have applied the fix I got through the tech support case, but I have not had time to test it yet.
Go to wherever your \Configuration\Shared\WebAssist\DataAssist folder is and open the file PageGeneration.js.
On line 375 you find wa_getConfigurationPath. It should be WA_getConfigurationPath (WA in caps).
See if that helps. It is a bug.
kristina429176
Having Same Issue
I am having the exact same error except I am on a PC and I am still using CS5.5. Please tell me where to go to change the file code so it will work.
neo314
What version of Windows? On Vista/Win7 it would be something be something like
C:\users\[user name]\AppData\Roaming\Adobe\Dreamweaver CS5.5\en_US\Configuration\Shared\WebAssist\DataAssist
P.S. there is no space in DataAssist, but it keeps showing up in the post. I do not know why.
kristina429176
I understand the path to the Data assist folder, but I have several files in the data assist folder. Which file inside the DataAssist folder does the correction need to be made to?
neo314
Originally Said By: kristina429176
Whoops. Sorry. I thought I included the file name in the post. I edited the reply, so don't kick yourself. It was not there before.
The file to edit is PageGeneration.js
kristina429176
Thanks for the file. I changed the path and then reran the wizard and it still gets stuck on the page creating the results page with the same error. Any ideas.
