Free Shipping Instruction
Thread began 5/26/2012 10:45 am by johna1964 | Last modified 5/29/2012 7:06 am by Jason Byrnes | 1573 views | 1 replies |
johna1964
Hi!
I am trying to add free shipping for customers if the total $ in the cart is above a certain amount.
Free shipping on items over a certain amount:
eCart object > shipping tab > plus icon > enter name of rule ie Free Shipping
Select the trigger
subtotal for the entire cart contents > 30.00 (for example)
I'm not understanding what calucation to select - (I'm thinking Based on Cart Subtotal) nor what needs to be entered into the text box.
I need some insight.
Thank you!
johna1964
for free shipping, you would need to add a condition to your existing shipping triggers so that they don't apply over a certain total amount. so if you want free shipping if the subtotal is over 30, add the following trigger to your existing shipping rules:
AND
subtotal for the entire cart contents < 30.00
johna1964
Hi again.
I have been trying to figure this out for a very long time.
I need to have a flat shipping for $0 - $29.99 of $5.90.
I need to be able to have a flat rate for $30.00 of $0
I cannot for the life of me figure out how to have both.
It is either 0 or 5.90 - the rule will not allow two calcuations regardless of the conditions applied.
The only way i could get a shipping discount to apply was through discounts and the discounts needs to have coupons discounts where I run into the same problem.
I have tried creating a new rule and trying to apply the specific conditions and flat rate calculations,- i have tried every way, but the right way apparently.
This seems like it should be an easy thing to do, but i can't seem to figure it out.
Please help.
Thank you,
johna1964
you posted another similar related question here:
showthread.php?p=140807#post140807
see my replay to that post.
johna1964
Hi Jason,
I have the free shipping issue solved thanks to you.
I just need help with getting the shipping/taxes showing when the customer is not logged in. (other thread).
...and again thank you.
johna1964
replied to other thread. see my reply there.
