Bug in eCart 5 - wa_appbuilder_php.php
Thread begun 5/21/2012 8:14 pm by Steve | Last modified 5/25/2012 7:59 am by Jason Byrnes | 1378 views | 1 replies |
Steve
Hello,
I updated a wizard generated confirm.php page regarding the email sending portion and had the page go blank on submission (confirm.php was blank).
I found that the page: wa_appbuilder_php.php
was coded to require_once(library.php)
But the file wa_appbuilder_php.php is in the webassist/email directory so it thinks that library.php is local
so.. I had to change the code to point to the actual library.php files location:
-    This file contains proprietary and confidential information from WebAssist.com
-    corporation.  Any unauthorized reuse, reproduction, or modification without
-    the prior written consent of WebAssist.com is strictly prohibited.
-    Copyright 2005-2007 WebAssist.com Corporation.  All rights reserved.
require_once("../framework/library.php");
// Application Builder functions
function WA_AB_getLoopedFieldName($tName, $loopInde) {
Bug or problem with the framework?
Details- Mac, latest everything including eCart
we are not able to reproduce this issue.
please provide more details, What version of eCart (I know you said latest version, but it really helps to use the version number for confirmation).
Is this using Data Bridge / Design Extender or the stand alone extension versions (Data Bridge / Design Extender would be the latest versions)?
what changes did you make in the universal email behavior?
