fixed footer problem
Thread begun 5/16/2012 6:24 am by CraigR | Last modified 5/17/2012 9:09 am by CraigR | 2455 views | 4 replies |
CraigRBeta Tester
I am trying to anchor a footer to the bottom of the page, (layout based on CSS sculptor template)
I have tried adjusting the negative margin of the footer and the margin of the content div, but whatever I do, there is always a white bar at the bottom of my page.
I tried highlighting the relevant divs to see if I could fix the problem, but no luck
xxx.php
Thanks for any help/advice
** Trying again, using CSS sculptor, creating a 2 column fixed, header and fixed footer template, making no changes, the layout is fine.
If, on choosing the same template, I edit it and choose a full width header, the footer is now below the bottom of the page**
in the CSSSculptor/2ColumnFixedHeaderandFixedFooter_lebbon3_css/screen.css file, change:
#fixedFullWidthFooter {
margin-top: -280px;
position: relative;
margin-top: -240px;
position: relative;
CraigRBeta Tester
Thanks Jason.
I've been there, all that does is push the footer down 40px so it is no longer anchored to the bottom of the screen but below it.
As I mentioned in my earlier post, the issue is there straight from CSS sculptor. If I edit the layout to full width header AND fixed full width footer.
The footer always sits below the bottom of the screen
Ok, I see what you mean, I have logged this in our bug base to be fixed in an upcoming update, i think the work around for now will be to edit the width of the footer to 100% after the page is created.
CraigRBeta Tester
Thanks Jason.
For now, I have gone back to standard width header with fixed footer and played with the background images to get close to what I wanted.
