Error message
Thread begun 5/13/2012 7:28 pm by ckaminski | Last modified 5/24/2012 9:13 am by Jason Byrnes | 5781 views | 9 replies |
ckaminski
Error message
When using serveral extensions including CSS Sculptor I get this error:
WA_localURLToFilePath is not defined
Any ideas?
Chuck
this error usually happens if you install one of the stand alone extensions after installing Design Extender or Data bridge.
Design Extender or Data Bridge should be the last extension you install.
see this thread for install tips.
elevy388997Beta Tester
I am having the same problem but I don't have any extensions installed that are in the main extensions:
Design Extender
Data Bridge
eCart
Tools for Google
Web Standards Advisor
Skype Button
Cookies Toolkit
Theme-It
Palette Picker
Surveyor
ckaminski
Works Great Now
Works Great Now
I uninstalled all the extensions.
I then re-install the eCart then the Data Bridge and last the Design Extender.
Chuck
Willi Schneider
Hi elevy388997
You have Cookies Toolkit, which got integrated in Security Assist and Theme It, which, at least I think, is part of CSS Sculptor.
Deleted Cookies ToolKit and installed everything in the order mentioned above... all is working fine!
brian358606
CSS Sculptor - Error Message - WA_localURLToFilePath is not defined
I purchased Super Site today and installed the three Dreamweaver extensions.
When I went to use Css Sculptor, I got the following error message:
After reading this post, I deleted the three extensions and added them back in this order:
First - ecart
Second - Data Bridge
Third - Design Extender
During the installation process there were a few pop-ups that said there was a newer file already installed and asked if I to use the newer. I am pretty sure I said to use the newer file.
When I went to use CSS Sculptor, I got the same message.
This is very frustrating. This is a long process of loading and unloading the extensions.
have you tried Deleting the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
If you still have the same error after deleting the cache file, I will start an incident so we can look into the issue with you and debug the cause.
brian358606
Deleting cache
Deleting the WA cache solved the problem. I was able to launch all three products.
Thanks.
Great, glad to hear it is working.
