Design exentender 1.06 - css menuwriter menu bad links on local server
Thread begun 5/13/2012 7:13 am by Antonino Stancampiano | Last modified 5/16/2012 1:44 pm by Jason Byrnes | 5348 views | 5 replies |
HI,
my menu is working on remote server but on local server i get :
file:///D:/myserver/master1/obiettivi.php.
I'm running easyphp 5.3.6.0.
Correct link it would be :
index.php
Mike Perry
Originally Said By: nucciost319288
  HI,
index.php
Do other localhost links display properly??
hi,
for all links on local server i get: file:///D:/myserver/master1/namepage.php
it would be : namepage.php
Before i get other type of error. on local server it was :
namepage.php(myserver/master1/ twice)
menu writer takes the links settings from your Dreamweaver site definition.
In your site settings, make sure you are using a valid URL for the HTTP Address setting of the local info category and for the URL PRefix in the testing server section.
another thing that may cause this is if you move the files within dreamweaver. on moving files dreamweaver will prompt you to update link paths, that can cause the file system paths you are describing to occur.
Page menu.php CssMenu Writer
Maybe it's not important but the menu.php page generated by CssMenuWriter is correct. All links are correct ...This change something on your answer ?
