Next Previous links on detail page
Thread begun 7/30/2009 9:08 am by kbettenc296716 | Last modified 9/01/2009 11:56 am by jw291405 | 2657 views | 2 replies |
kbettenc296716
I need to put previous and next links on a detail page. I have only seen instructions online for repeat regions. Is there someway DataAssist does this and I just haven't noticed? Is there a reasonable way of doing this.
For background:
There is a master page created by DataAssist with images in a grid. When the user clicks on an image they are taken to the detail page, with a larger image and details. I want to have Previous and Next links on the detail page, so that the user doesn't have to go back to the master page to see another image.
Any help you can offer would be super.
You would have to change the way that it works....
Currently the results page only passes the ID of the detail record. This means it doesn't know what record would be previous or next based on the search or anything else on the details page.
In order to do it you would probably have to use the same recordset on the details page that you use on your results page, and instead of passing the ID you would have to pass the index of the record in the result set. Then you could navigate by incrementing and decrimenting the increment in the url you are using to keep track of the record displayed.
This will require cutting and pasting of the recordset code and probably a small amount of coding by hand to navigate to the correct records based on index.
jw291405
I thought I saw a result page with such navigation buttons. I think there is even a tutorial on it.
