Crashes Dreamweaver CS6 On Startup
Thread begun 5/10/2012 6:04 am by MikeyT | Last modified 8/06/2013 1:56 pm by Ray Borduin | 10697 views | 6 replies |
MikeyT
I figured out through the process of elimination that this was the extension causing DW CS6 to crash on startup. I know its not supported for the new version of DW, but thought I'd throw this out there in case anyone else is experiencing the same. So far, other legacy extensions outside of Design Extender, Data Bridge, and eCart seem to be working okay in CS6.
Thanks for posting this.
MikeyT
No problem, Jason.
randy299647
When will this be fixed?
I dont currently have a time line or when Dreamweaver Tools For Google will be updated for DW CS6.
gbeth372480
any updates? just installed Data Bridge (the 399 package for 149) and these problems started. Uninstalled WA extensions, still same problem.
Try deleting the winfilecache .dat file.
If it crashes on startup it probably means it is one of the files in either the Configuration/Startup directory or Configuration/Floaters... those are the only files that run on startup. You could try renaming those folders one at a time to narrow down the cause and then maybe removing single files from those directories to really pinpoint the file causing the problem.
My best bet is that deleting the cache file will probably fix this issue. If not, please post your phone number in the private message area and we can give you a call to help debug it.
