Security Assist Page Redirect For Logged In Users
Thread begun 5/07/2012 6:32 pm by Mysite07430650 | Last modified 6/07/2013 6:51 am by Jason Byrnes | 8840 views | 11 replies |
Mysite07430650
Hello All,
I have finished creating the relevant pages for user to register, login, logout and update their information. Although the forms are functional it can be pretty cumbersome for users to be on for example Page A click on the Log In link on Page A and be redirected to the Login page after successfully logging in; only to click the go to previous page on the browser to return back to Page A.
Is it possible instead for Users clicking on the Log In Link on Page A, be redirected back to the same Page A after they have successfully logged in.
Can this be applied to all the pages created within Security Assist, so that when a User is logged out, the Log Out page shows briefly only to redirect the user back to the original page where the Log Out link was clicked.
Thank you in advance.
for the login link use the following code:
<a href="/login.php?accesscheck=<?php echo htmlspecialchars($_SERVER["PHP_SELF"]); ?>">Login</a>
for the logout link, use:
<a href="/logout.php?accesscheck=<?php echo htmlspecialchars($_SERVER["PHP_SELF"]); ?>">Login</a>
on the login page, make sure the action of the form uses the following code:
 action="<?php echo htmlspecialchars($_SERVER["PHP_SELF"]); ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".htmlspecialchars($_SERVER["QUERY_STRING"]):""; ?>"
on the logout page, add an access restriction to restrict access to only allow logged in users, make sure the access restriction code is after the clear session code on the logout page.
that should do the trick.
Mysite07430650
Hello Jason,
I have inserted the code as instructed and ensured the restrictions applied to the Log Out Page came after the Session Code. The problem arises when you are not logged on but click on the Logout link and expected to be redirected to a page selected in Manage Page Access, instead I get an error out captured in the image attached.
What do I do?
Thanks for your help.
send a copy of the logout page please
Mysite07430650
Here is a copy of the Logout Page.
Mysite07430650
Database Connection Failure on Live Testing
I wanted to test live the pages created with Security Assist on the live server and I did as follows:
[1] I Exported the database including table for Security Assist to Remote Server.
[2] I imported the database into Remote Server using PHPMyAdmin and was able to confirm the database, username and password are indeed present in remote server.
[3] I uploaded the Secuirty Assist created pages and other relevant pages in protected.
[4] Previewed the Login Page and got the following error message detailed in the screen capture image attached.
Please help!
Thank you.
Mysite07430650
Originally Said By: Mysite07430650
Hello Jason,
I know you must be very busy with dealing with so many enquiry. I just wanted to remind you that I have sent the logout page as requested. I would also appreciate guidance on how to go about fulfilling the database requirement for Security Assist in order to go live. I seem to be experiencing problems with that.
Thank you.
h150477
I solved it in the userupdate form by moving the code that shows when successfully updated from the top of the page to the bottom. Its logical to put this code at the bottom instead of the top as it stops the form from jumping up and down.
<?php if(WA_Auth_RulePasses("Successful update")){ // Begin Show Region ?>
<p>Information updated successfully</p>
<p> Please <span class="menbut"><a href="login.php">log in</a></span> to continue</p>
<?php } // End Show Region ?>
That done insert the following code after it within the same show region.
All this does is create a button round the log in text which only shows after a successful result.
When clicked it then redirects to the login page in case the user has changed the password.
You can use this in most of the forms to redirect to any page on your site just by changing the href..
Mysite07430650
Originally Said By: h150477
Hello h150477,
Is this solution to a problem you had experienced or do you consider it a general workaorund for the userupdate php file? Did you experience same problem that I am having with Security Assist pages?
I am still waiting for support to contact me?
