unable to change "Full Width Header" text
Thread begun 5/06/2012 9:51 pm by rhodesdoug425533 | Last modified 5/16/2012 7:25 am by Jason Byrnes | 3385 views | 3 replies |
rhodesdoug425533
I created a new site with Site Sculpter using a .dwt template created by CSS Sculpter.
Everything works. However I cannot figure out how to change the full-width header text.
All of the CSS is greyed out and I cannot modify it.....
Change the text in the header by editing the site assist template file that is created in the Templates folder of your site.
the header is not an editable region, so you need to change it on your template.
rhodesdoug425533
changing the template
...thank you jason. Did change the .dwt template, that did not do it, because, I guess, the page is already created and not linked to .dwt like it is to a css file.....
so do i need to modift the .dwt THEN re-make the page based onthe changed template?
you dont need to remake the pages. When you save the template, you should be prompted to apply the changes to pages based on the template. If you are not prompted to apply the changes, you will need to force dreamweaver to apply them.
go to Modify -> Templates -> Update Pages
