Adding font
Thread begun 5/02/2012 3:38 am by chris4754 | Last modified 5/02/2012 7:50 am by Jason Byrnes | 1185 views | 1 replies |
chris4754
Adding font
what's the best way to add a font to the CSS?
The client has decided that they want Calibri for the Long, Short and Checkout descriptions. They can change the font when creating those descriptions, but given that this would mean doing 1200 changes, they would prefer it if there was a way of doing it automatically/by default
If the viewer doesn't have that font, does that cause problems?
using FireFox with the firebug plugin, you can inspect the power store pages to find the specific elements you want to apply the font to to find the class name or ID for the div. For example, the long description div has an id of "ProductLongDesc":
<div id="ProductLongDesc">
here is an article that talks about using Firebug:
roadmap_10.php
once you know the div class name of ID, you can create a css rule to apply the calibri font. you will probably want to use a font-family, this way you can set alternate fonts that will be used if the calibri font is not installed. you would want to add your custom styles to the webassist/themes/<your theme>/css/configurable.css file at the end, for example:
#ProductLongDesc {
font-family: Calibri, Candara, Segoe, "Segoe UI", Optima, Arial, sans-serif;
