2 error messages on loading DW
Thread begun 5/01/2012 1:20 am by CraigR | Last modified 5/01/2012 7:17 am by Jason Byrnes | 1739 views | 3 replies |
CraigRBeta Tester
Just installed the following extensions in the following order..
ecart 5.0.3
design extender 1.0.4
data bridge 1.0.0
and get 2 error pop-ups on loading DW
(DW5, Windows 7 Professional x64)
cleared the cache as usual, makes no difference
YellowCircleWeb
Here is a post I found that should help you with your second error message:
For "unable to find" errors just go to "Window->Workspace Layout->Refresh 'your workspace'"
That will clear up those errors... that one isn't a bug it is just Dreamweaver remembering that you had an old floating panel open that we either renamed or removed in this version.
That post was from Ray @ WA
CraigRBeta Tester
Thanks Ian, that fixed the second error.
Just one to go !
Just realised, this error has been logged already showthread.php?t=26159
Yes, Craig, we hope to have a fix for that error released soon.
in reality, it is just a nuisance error that should not effect functionality if you ignore it, but we will be releasing a fix for it soon.
