JavaScript Error Applying Repeat Selection SB
Thread begun 4/26/2012 4:11 pm by Lee Firth | Last modified 4/26/2012 6:35 pm by Jason Byrnes | 1606 views | 3 replies |
Lee Firth
I am trying to apply the DataAssist Repeat Selection server behavior, but get the attached error message.
I have tried deleting WinFileCache file but it still happens.
That error indicates a problem with the selection made on the page that you are adding the repeat selection behavior to.
Can you send a copy of the page and a screen shot of dreamweaver in split view showing what part of the page is selected when you add the repeat selection behavior, please add the screen shoot to the same zip archive as the page.
Lee Firth
Files are attached.
you page has an extra <!-- InstanceEnd --> tag just before the closing </html> tag that is causing the problem.
this may be in the template, or you may need to use an external text editor to remove it.
<!-- InstanceEnd --></html>
there is no beginning template instance to match that ending editable area tag.
