MySQL Error#: 2000
Thread begun 4/25/2012 8:56 am by admin140217 | Last modified 4/29/2012 10:47 pm by admin140217 | 10338 views | 6 replies |
admin140217
MySQL Error#: 2000
I'm getting a MySQL Error#:2000 when I try to define the PowerCMS Builder MySQL connection. see attached screen shot. I did not set up the database but the info was given to me.
Is this something I'm doing or is it on the database side of things.
If this helps, here is the software version:
Software version: 5.0.41-community-log - MySQL Community Edition (GPL)
see this thread on stack overflow for details on fixing this:
cannot-connect-to-mysql-4-1-using-old-authentication
admin140217
Connection made, getting other errors
I was able to make the connection but now I am getting other error messages with regard to the responce of the database server, then asks me to click the define button to check the database connection.
I know the connection is good, I know that all permissions are set properly so I'm a bit confused. This is the first time I'm trying to use PowerCMS Builder. I noticed when I first used it that it had given me an option telling me that not all dependant files were needed at that time so I chose not to add dependant at this time so the only new folder I see in the site structure is the connections folder, are there supposed to be more than that?
Help with this would be great.
are you connecting to a Local mySQL Database? or a remote MySQL Database server?
If you are connecting to a remote database server, you may have to contact the host to have you IP address added to the allowed list.
the remote server may be set to disallow connections from unknown hosts.
admin140217
Yup, I asked them to check that and am waiting for the reply.
admin140217
Update
I have gotten nowhere:
I have started from scratch and re-installed the extension, removed and re-created the database connection string and I am still ending up with the password message.
Things I have done...
I have tested locally and all works well, fast connection, no errors
I have used a different tool for the sake of making a connection and connected to the database with MySQL Workbench, this connection happened very fast with no errors.
To me the fact that I was able to connect using a different tool tells me that my IP address is approved and the password issue is not present.
So my question is, is this a problem with DW CS4/CS5.5 or the extesion?
admin140217
solved
I seemed to have solved this issue but have another, will be posting a new thread.
