Checkout Wizard and UE - Re Enter?
Thread begun 4/08/2012 10:32 am by elevy388997 | Last modified 4/09/2012 8:26 am by Jason Byrnes | 1135 views | 1 replies |
elevy388997Beta Tester
I was using the checkout wizard and at first I noticed that I forgot to have the shipping address displayed so I just reentered the wizard through the insert menu and found out that it doesn't update the pages even though all my information was still saved in there.
Second I looked at the support pdf and saw that it is supposed to go into universal email to make a receipt, and mine did not do this (i have UE/CSS form builder installed).
How can I modify the checkout pages once they are created? If I can't what do I delete so when I do reenter the wizard, it creates new pages? And how can I have a receipt created?
The checkout wizard is not reentrant, if you need to run the checkout wizard again, you will need to delete the pages that where created the first time:
checkout.php
confirm.php
checkout_success.php
checkout_failure.php
pp_confirm.php
pp_checkout_success.php
pp_checkout_failure.php
some of these pages may not be created, they depend on the settings you use in the checkout wizard.
the option to create an email receipt using Universal Email will only be available if you are using a local checkout method, if you select to use a remote checkout method, the gateway will handle sending the receipt.
