eCart Shipping Upgrade Options
Thread begun 4/05/2012 5:23 pm by toni272059 | Last modified 4/09/2012 1:20 pm by toni272059 | 4524 views | 8 replies |
toni272059
I have setup shipping options based on Quantity of product in shopping cart for standard shipping based on Country in Checkout.
USA First Class $5.00 for first item then $1 for each additional item
International $7.00 for first item then $1 for each additional item
I would like to add option on shopping cart page to upgrade USA to Priority (+$2.00) or Overnight (+$7.50)
I followed the instructions on an earlier post (12-07-2009, 01:23 AM david331670) and created form fields on the cart page with check boxes to add an upgrade for either priority or overnight shipping, added hidden fields on the confirm page and added shipping options in the eCart.
No price increase is added if upgrade selected on cart page.
Attached are the cart, confirm pages and eCart1_PHP.php
Work in progress website : www.johnpripheritagecollection.com/
It is not currently attached to its PayPal account as don't want to risk the wrong shipping being calculated. Sales tax to RI customers only.
What am I missing?
thanks
you added the checkboxes to the cart display page, this page posts to itself, then redirects to the checkout page.
instead of adding the behaviors to set the session variables for priority and overnight on the confirm page, you need to add them to the cart display page.
toni272059
Thank you!
toni272059
I spoke too soon!
Question -- currently with checkboxes there is the chance someone can select both and get charged for both priority and overnight shipping upgrades
I tried changing to radio buttons but to be a group they need to have the same name. When I changed name for both to upgrade the upgrade fee stopped being added
if($_SERVER["REQUEST_METHOD"] == "POST") {
$_SESSION["upgrade"] = "".((isset($_POST["priority"]))?$_POST["priority"]:"") ."";
$_SESSION["upgrade"] = "".((isset($_POST["overnight"]))?$_POST["overnight"]:"") ."";
<input name="upgrade" type="radio" value="1" id="priority" />
USPS Priority : +$2.00<br />
<input name="upgrade" type="radio" value="1" id="overnight" />
USPS Overnight : +$7.50
radio button is really the only way to go, but with the radio button, you willl need to set the value to to either priority or overnight:
<input name="upgrade" type="radio" value="priority" id="priority" />
<input name="upgrade" type="radio" value="overnight" id="overnight" />
you will only need one set session behavior to set the upgrade session variable:
$_SESSION["upgrade"] = "".((isset($_POST["upgrade"]))?$_POST["upgrade"]:"") ."";
the in the shipping rule for the priority, set the trigger to:
Session Variable 'upgrade' exists
AND
Based on session variable value:
if the session variable 'upgrade' has a value of 'priority'
flat rate of '2.00'
and in the shipping rule for overnight:
AND
if the session variable 'upgrade' has a value of 'overnight'
flat rate of '7.50'
toni272059
OK, everything is working correctly.
Next step:
I have added dynamic text before the word 'Shipping' on the Confirm page so whatever shipping option selected on the shopping cart page will be repeated. <td class="eC_SummaryLabel"><?php echo $_SESSION['upgrade']; ?> Shipping</td>
Result -- First Class Shipping, Priority Shipping, or Overnight Shipping
All works great for USA shipping
However, if someone selects an upgrade and the shipping address is outside the US, while the additional shipping fee will not be added (I created shipping rules) the name still appears before Shipping.
Is there a way I can create a function that if shipping address is not US only show First Class (regardless of which radio button selected on shopping cart page)?
this should do it for you:
<td class="eC_SummaryLabel"><?php echo((isset($_SESSION['eCartCheckoutForm_shipping_country']) && $_SESSION['eCartCheckoutForm_shipping_country'] == "US")?$_SESSION['upgrade']:"First Class"); ?> Shipping</td>
toms016390756
The things you learn in these forums is priceless. Thanks!
toni272059
Perfect, thanks again!
