Can you add pages in PCMS w/out setting up in Site Sculptor?
Thread begun 3/23/2012 6:26 am by Jared Lui | Last modified 3/23/2012 10:24 am by Jason Byrnes | 1087 views | 1 replies |
Jared Lui
In other words. Is it possible to add a .dwt to a CMS that you created without using Site Sculptor. What exactly triggers the CMS "Add Page" function?
As the web master I can manually add pages all day when/if needed. However I'd like to be able to give the client the ability to add pages using the CMS but without having to create pages using Site Sculptor.
when you create a new content region in Power CMS, you have the option to use it as a page template.
you can then create new pages from the CMS template, these are virtual pages that change the content being displayed by use of a QueryString Variable.
you only need to create the one physical page with the developer notes from power CMS on it, you can then create new pages from the template in the power CMS admin panel, and change which pages content is displayed by changing the Query string variable.
