PCMS not working in <head></head> tags?
Thread begun 3/21/2012 8:11 am by Jared Lui | Last modified 3/21/2012 10:17 am by Jason Byrnes | 1388 views | 2 replies |
Jared Lui
At least it is not now.
I finally got CMS to get through the install (had an issue trying to get my host to enable SSL) and did a test content section on a index.php page I created and it worked fine.
So I began from the top down to create the regions that my client wants to be able to edit. The first one was the <title>. I selected the text within the <title></title> tags and selected Webassist/CMS/add content to PCMS and the dialog came up and did that all fine. DW and WebAssist did their magic and the code eventually popped up on the screen. The database was updated and I could see the new content group in the Admin. All I had to do was save the index.php file and upload it to my server (I test on my live server rather than locally).
I noticed that it cropped part of the title text and included the <title></title> tags in the database and the admin which I found to be weird since I did not select them and some of the text was missing.
So I deleted this using the admin delete function and then tried another section of the page to see if that would happen again. Went to another section in the body of the page and it worked fine, no issues.
Tried the <title> tag again and when I try Webassist/CMS/add content to PCMS I get this message "Please make a selection in your document before trying to use this option."
I tried it with the <meta> tags and then with only the content within the meta tags and the same thing comes up. I then tried the body content and that is fine. Tried the head content and keep getting that message.
My question is can you or can't you create editable regions in the head section or did my software screw up somehow when I deleted that first one. And any ideas how to fix this?
Can I use the same formatting as one of the other sections and manually create a editable region on the page and add the content to the database manually?
And as an FYI, I see the original Title tag text in the history on both the admin side and in the database of course.
Thoughts?
Jared Lui
Still have no clue why I get that message now and it wont allow me to use the WebAssist tool to add them but I did try to manually add the meta description into the index.php doc and the database and that worked, so I have a workaround.
I'll try uninstalling/reinstalling Design Extender later and see if that clears it up. (edited - tried deleting the wincache dat file and uninstalled/reinstalled and it still does the same thing)
Here's my code: look correct?
<meta name="description" content="<?php echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Home Page', 'Meta Description'); ?>"/>
this is a limitation to the tool, it will not allow you to create a content area from the elements in the head, or add content from the CMS in the head region, I will log this as a bug to be investigated, in the mean time, the work around you have found is correct, create the content area in the CMS Admin, then add the developer notes code to the page.
