Yet again i cannot connect to database
Thread begun 3/19/2012 7:05 am by niall_mcguinness417202 | Last modified 3/19/2012 10:33 am by Jason Byrnes | 4780 views | 14 replies |
Unidentified error
Got past the Unknown error
Now something about 404
the unidentified error means that either there is a problem with the Dreamweaver Site definition, specifically in the settings for connecting to the testing server.
Go to Sites -> Manage Site
select your site and click edit.
if you are using DW CS5.x Go to Servers, and edit the one that has the testing check box selected.
in DW CS 4 or lower, make sure you are using advanced view, and select the Testing Server category.
What are the settings you have entered for connecting to the testing server?
Are you connecting to a local testing server or a remote testing server?
do you have the correct address entered for the URL Prefix (Web URL in DW CS5.x)?
If you are using the remote server as your testing server, is the host directory set correctly? this should be set so it maps to the same location as the Web URL.
for example, if you connecting to the server through FTP, you may be connecting to the server in a folder below the webspace, you may have a folder named htpdocs which is the folder that your webpages are served from, if this is the case, make sure that you enter that folder in the host directory setting so that the connection made by dreamweaver is to the same location as the web url,
testing server
What is a testing server?
I am not using a server to test the site
I am just up loading it to my server
This seems to be defined already
what should go here?
It connects to the testing server
Still cannot connect
I still cannot connect
Slowly getting there
I have connected to the server - HOORAY
Now its telling me it is unable to edit my database
this is still an issue with the site settings, most likely it is an issue with the Host Directory setting in the Testing server settings.
If you go to the files panel, and change from viewing the local server to viewing the testing server what do you see, can you send a screen shot.
Forum
Your forum wont allo me to uplaod the file
Please advise
what is the file type?
you can compress it to a zip archive and attach the zip file.
