Social Media, Design extender & Powerstore
Thread begun 3/16/2012 8:53 am by JOE352699 | Last modified 3/19/2012 9:49 am by Jason Byrnes | 1693 views | 3 replies |
JOE352699
I was told by sales that Social Media would work with a site created by your power store 4.5,the dreamweaver extentions loaded fine but I am unable to alter the PHP built pages in any way, could you please point me in the correct direction to add social media to my index.php page.
Thank you
Joe
before beginning, see the FAQ Section of the Power Store support page, specifically the question "Can I use WebAssist Extensions to modify the Solutions?":
powerstore/
to add social media toolkit to the index page, you will need to edit the webassist/themes/<your theme>/templates/install.dwt.php file.
JOE352699
social media
is not found, could it be: webassist/themes/<your theme>/templates/index.dwt.php file.
when I try to use social media on a test page all the icons stack vertical as well.
checking other threads said to look out for the <head>, here is a copy of mine
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
<!-- TemplateBeginEditable name="doctitle" -->
<title>Page Name - <?php echo($WAGLOBAL_Site_Name); ?></title>
<!-- TemplateEndEditable -->
<?php echo($WAPageMenu->Head); ?>
<?php echo((isset($WASideMenu))?$WASideMenu->Head:""); ?>
<!-- TemplateBeginEditable name="head" -->
<link rel="stylesheet" type="text/css" href="../../../../webassist/social/wasocial.css"/>
<script type="text/javascript" src="../../../../webassist/social/wasocial.js"></script>
<link rel="stylesheet" type="text/css" href="../css/crazy_form.css" />
<link rel="stylesheet" type="text/css" href="../css/crazy_styles.css" />
<link rel="stylesheet" type="text/css" href="../css/configurable.css" />
<!--[if IE 6]>
<link rel="stylesheet" type="text/css" href="../css/ie6.css" />
<![endif]-->
</head>
Thank you.
yes, sorry, index.dwt.php is the correct template page.
vertical stacking usually happens if the link to the /wasocial.css file is missing, but i see that in your code:
if you provide a link where i can see the problem i can diagnose the cause.
