Creating page layout
Thread began 3/10/2012 7:12 am by dvan_zelst | Last modified 3/12/2012 7:21 pm by dvan_zelst | 799 views | 2 replies |
dvan_zelst
Hi, i was hoping someone could advise me which procedure to follow to create a content page layout. Sofar i did the following:
1: Created a 1 column fixed layout with header, topnav, content and footer DIV using CSS sculptor
2: Added my footer and header image into this layout
3: created a Menuwriter menu on a seperate page and included it as a plugin into my page layout with FrameBuilder static plugin
4: Converted the completed layout into DW template and set the content area as editable region
5: Converted the template into a Frambuilder Theme
6: Created a new page from the FB Theme
Sofar so good and all works well. But how should i continue from here. I would like to have my content area laid out differently from page to page with DIV's.
Can i just use CSS sculptor again inside my editable content area to layout my content area for that page? If i do the layout in my template then every content page layout will look the same.
Thanks.
Dave
The content area layout you will need to create from page to page. you wont use CSAS Sculptor to create it though, you will need to create it manually.
CSS Sculptor is used to create a full page layout, not just the one content area piece.
dvan_zelst
Hi Jason,
Thanks for your clear answer, i was already affraid you would say that :-)
Maybe it would be a nice feature added to CSS sculptor to be able to also create page layouts as well. I really liked using this extension to create the full page layout and would have been great if i could use the same extension to create the page layouts as well.
Dave.
