IRite issue
Thread begun 2/27/2012 3:53 am by russell298997 | Last modified 2/28/2012 11:09 am by Jason Byrnes | 3035 views | 6 replies |
russell298997
IRite issue
Am still using iRite as am bout to change to PHP but still have lots of ASP sites running.
I guess youm wont support this any more but just wondered if you can shed any light on a really annoying glitch..
When i add a link in iRite it asks for PROTOCAL so i put in http:// - i then add full path URL and all is fine.
soon as i go back in and do any other updates it changes the PROTOCOL to "other" and wraps "" around my URl so
contact.asp
becomes
""http://www.solarsense-uk.com/contact.asp""
the resultant live link becomes
contact.asp%22%22
do you know of any way round this issue short term whilst i get to grips with transferring to PHP and rebuilding all sites. it is a massive headache - thanks for any advice!
in the initial value setting for irite, is there formatting for converting the " characters to the HTML entity "& quote;" (added space so it wouldn't be converted)
try rebinding the initial value to remove any formatting.
russell298997
iRite
the only options i can see are to
Encode HTML entities
ENcode Non-ASCII characters
have tried checking/unchecking but no difference.
There is an option to
Encode additional
but i dont know whether that's relevant or which character would specify....
russell298997
it just appears to be writing a pair of quote marks around the link each time the page updates, adds a new pair each time.
there must be a way to tell it to not do that...?!
please send a copy of your page.
russell298997
attached - thanks for looking at it.
if you want to look at it happening live in client CMS i can send log in....
yeah, the initial value for each of the iRite instances is using the replace function to convert the " to the html entity.
edit the iRite instance, click the lightning bolt next to initial value and reselect the corresponding column from the recordset, this will remove the replace function code.
