Cant login to power gallery
Hi there i cant access the power gallery on my site. ive uploaded all the files, i renamed the folder powergallery and tried to access it by typing the following address;
index.php.
please help
index.php.
please help
this is coming up as a blank page which means a php error has occurred, but error reporting is turned off. add the following code at line 1 to turn error reporting on:
error_reporting(E_ALL);
?>hi and thanks, also am i able to use this software for all my clients domain names, and is it possible for them to have their own unique username and password so they may setup and make changes to their own galleries?
The licensing for power gallery allows you to install it on one live domain, and one testing server. to install it on additional domains, you will need to purchase additional licenses.
contact the sales department and they will be able to give you details about volume licensing discounts.
for each domain, you will create a database for the gallery, each install will have a separate login.
for some reason i still cant login. i just keep getting a blank page
