Default location not displayed when inculde directions is checked
Thread begun 2/20/2012 10:18 am by Dennis | Last modified 2/21/2012 9:53 am by Ray Borduin | 2311 views | 3 replies |
Dennis
With the new version of Pro Maps in WADE 1.0.1 the default location does not appear in the map when include directions is checked. The location is valid because the directions lead to the proper location and it does appear when include directions is unchecked.
Also when I customize the info window, which I do often, and finish the wizard. The next time I open the wizard those customizations are lost and all the locations are set to the default info window. This is a huge inconvenience when making ongoing changes to the map.
Map site: 2012_National.php#map
Thanks,
Dennis
Directions in the v3 API work differently and I can't seem to figure out how to get the info window to open... I'll look into it more.
I was able to reproduce the problem with custom info window text and I'll make sure that gets fixed in our next update which should be ready in about a week.
Dennis
Thanks Ray,
Just to add clarification, it is not just the info window that doesn’t display when include directions is checked but neither does the address marker. The location appears to not exist, yet the directions will lead to the correct location.
Dennis
I see... ok I think I have this resolved. We should have a new build out with these fixes shortly.
