Do I need anything from MySQL?
Thread begun 2/16/2012 5:36 pm by misplacedmoose426595 | Last modified 2/19/2012 8:56 am by CraigR | 2823 views | 3 replies |
Hi, I'm a newbie just getting started. I purchased Dynamic Suite and have set up a XAMPP local testing server. Does this give me all the MySQL language/programming I need to add a shopping cart to my website, or do I have to install something from the MySQL website?
XAMPP installs an Apache web server for serving web pages.
It configures the PHP processor for the apache server so that PHP code added to your pages can be executed.
It installs the MySQL database server.
and Through the XMAP Controll panel, you can Launch the PHPMyAdmin page which allows you to manage the MySQL Database server for Creating new databases and adding table and viewing content.
to begin creating a Dynamic website that connects to a database, that is the basics of what you need.
The next step is to create the database your site will use. we offer a free eCommerce database here:
ecommerce-database/
that you can use as a starting point. refer to the "How to import a MySQL (.SQL) file to your database" tutorial on the learning resources page for detail on installing the eCommerce database to your MySQL server:
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
With your database set up in the MySQL Server, you can begin defining your site in Dreamweaver and creating the database connection, there are further tutorials for these topics on the learning resources page
RonnieJaysmith
Based on the opinions expressed from other customers, OsCommerce is the most feature-rich, but requires a lot more patience since it's more in-depth configure-wise. Zencart is basically a 'dumbed-down' version of OSC, and though it is developed separately it's very similar in setup, but easier to use. Most customers think Cubecart is the most user-friendly, yet at the same time it has many of the same features as the other two.
Regards,
Ronnie
CraigRBeta Tester
... and those looking for support in this forum would probably be using eCart !
