two different powerstores
Thread begun 2/13/2012 4:36 am by Marleen | Last modified 2/15/2012 1:17 pm by Jason Byrnes | 8917 views | 23 replies |
Marleen
Hi, I asked if I could have 2 powerstores on different url's and if I could copy my shop (in dutch) to the second url and work from there. I got your answer that this was possible if I bought a second licence and after installing copy the old shop over the new installation. I asked if the licence code for the newer version could work on the older dutch version. There was no problem and it should work.
So I did what was told and placed two different licence codes in the shop.
Unfortunally all went wrong after that and both shops are intertwined. The passwords for the admin on the site change on both admins. Cms changes, dbases changes etc.
What can I do????
you have to install the 2 different stores to 2 different locations.
it sounds like you have installed the 2 stores in the same location. you need to use 2 separate locations and 2 separate databases.
Marleen
Hi Jason,
No I didn't store them in the same location. I uploaded it to another domain with the same provider with the two different license numbers. Webassist told me that I could cope the store over. I did that without the admin.
What happens now is that I open up the one admin to work on the second store and I end up in the admin of the first one. If I change the layout or the settings it is done in both stores.
I wanted to copy the db to the newer domain, so I needn't fill in all the articles again and the import on the new store is not working. it tells me that I don't have permission to use the dbase.
How can I get the seperation between the stores working again?
Marleen
Jason, I am working with a deadline. Can you please help me with this?
Marleen.
MagicBeta Tester
Link?
Marleen,
Do you have a link to see what is happening?
Magic
Marleen
the link is www.eko-fashion.nl
MagicBeta Tester
it looks okay to me except the images. I guess you forgot the copy /imagesupload directory(incl. the all pics) from the existing directory.
Marleen
no I didn't: all is present on the domain dir, but the pictures are not the problem. It is in the admin of the stores and the dbase. I don't understand why.
MagicBeta Tester
Are you not able to login to the admin area anymore?
Marleen
yes, Magic. but there seems to be just one. If i change something in the admin for the one store, it changes in the other also.
