Problem with security assist and a PCMS Builder template
Thread begun 2/10/2012 4:54 pm by mrs | Last modified 2/13/2012 12:55 pm by Jason Byrnes | 6467 views | 6 replies |
mrs
Hi, I have responded to a ticket, but I haven't heard back yet. My problem is that I have created a new template from the admin template created by PCMS Builder - I've simply changed one of the divs to be full page width - but even though nothing else has changed, when I test the pages created, page access just doesn't work. The pages just fail to load.
I am at my wits end now as I just don't know what else to do other than start from scratch without PCMS Builder... that'll take me days, if not weeks!
I'd like to use DataAssist if I can't use PCMS Bulder, but unfortunately, that's not working either!
mrs
I have just tried DataAssist with the PCMS Builder admin template, and as usual the results page now has errors...
Warning: mysql_select_db() expects parameter 2 to be resource, null given in /Users/matthewstuart/Sites/bearmach/admin_cms/news.php on line 49
Warning: mysql_query() expects parameter 2 to be resource, null given in /Users/matthewstuart/Sites/bearmach/admin_cms/news.php on line 52
This is lines 49 to 53:
mysql_select_db($database_PowerCMSConnection, $PowerCMSConnection);
$query_WADAtbl_news = "SELECT fld_id, fld_headline, fld_keyarticle, fld_intro, fld_show FROM tbl_news ORDER BY fld_date DESC";
$query_limit_WADAtbl_news = sprintf("%s LIMIT %d, %d", $query_WADAtbl_news, $startRow_WADAtbl_news, $maxRows_WADAtbl_news);
$WADAtbl_news = mysql_query($query_limit_WADAtbl_news, $PowerCMSConnection) or die(mysql_error());
$row_WADAtbl_news = mysql_fetch_assoc($WADAtbl_news);
I've gone through the same process for three days now and I am getting nowhere, so please help!
mrs
This is what I get when I test the insert page:
Warning: mysql_select_db() expects parameter 2 to be resource, null given in /Users/matthewstuart/Sites/bearmach/admin_cms/tbl_news_Insert.php on line 25
Warning: mysql_query() expects parameter 2 to be resource, null given in /Users/matthewstuart/Sites/bearmach/admin_cms/tbl_news_Insert.php on line 29
and this is line 25 to 29:
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
mrs
This is what I get when I test the update page (I have to manually type the address and the URL parameter to get at this error because the results page isn't working):
Warning: mysql_select_db() expects parameter 2 to be resource, null given in /Users/matthewstuart/Sites/bearmach/admin_cms/tbl_news_Update.php on line 43
Warning: mysql_query() expects parameter 2 to be resource, null given in /Users/matthewstuart/Sites/bearmach/admin_cms/tbl_news_Update.php on line 45
Lines 43 to 47 are:
$query_WADAtbl_news = sprintf("SELECT fld_id, fld_headline, fld_intro, fld_body, fld_keyarticle, fld_show FROM tbl_news WHERE fld_id = %s", GetSQLValueString($Paramfld_id_WADAtbl_news, "int"));
$WADAtbl_news = mysql_query($query_WADAtbl_news, $PowerCMSConnection) or die(mysql_error());
$totalRows_WADAtbl_news = mysql_num_rows($WADAtbl_news);?>
please compress each of these file into a zip archive and attach the zip archive so i can see the full page code in context, the snippets are not quite enough for troubleshooting the error.
mrs
OK, so I have rebuilt the pages I needed to build with DataAssist and it is working to a degree. I have used the same template (unedited) that the PowerCMS Builder uses to ensure that I am not getting any security assist issues in displaying protected pages.
The problems I was having with MySQL was that the include files such as DB connections were being placed after recordsets just before the head of the html. This meant the the recordset was trying to call info from a database before it knew where to look for the database. Simply moving all connections files to the top of the code has stopped MySQL errors, but I still have some issues.
My problems now are as follows:
1. Pages created by DataAssist are not redirecting on insert or update to the correct place when it is test locally. The URL is changing from:
etc
to this
etc
or
etc
It's sort of creating the path twice or changing the path from a webserver address to a disk directory address, however, this isn't an issue on the live server! It works fine there.
2. The admin_cms style sheets on my local computer are displaying correctly, but on the remote server, the style sheets are broken, it's as though I have disabled styles in my browser. This means I can't edit anything that is on the home page of the admin section. This is the third time I have uploaded the site now, so it can't be missing a style surely... can it?
What do you want me to do? Do you want me to zip the whole site up for you?
Thanks.
Mat
MarkNewsom
Opening Tickets
I really hate trying to find solutions to my problems here on the free forum and then find at the bottom of a thread where a Webassist employee says they are going to open a ticket and then it drops off after that unless you are the person the ticket was opened for. Can we begin a new practice where we try to keep things out in the open so we all can see the contents of the solutions that might have been discussed in the ticket to that one user?
are you having a similar problem? if you post the details of the problem you are facing, I will be happy to look into it with you.
