wishlist
Thread begun 1/30/2012 8:31 am by this_is_me | Last modified 2/03/2012 12:51 am by this_is_me | 1665 views | 2 replies |
this_is_me
wishlist
I am glad that version 2.10 is working now as expected. What I always miss is the administration of menus for websites. We often have one or two, sometimes even three levels of menus which need to have proper administration. I solve it with a query like:
mysql_select_db($database_mydatabase, $mydatabase);
$query_rsCatselect = "SELECT main.header AS mainheader, main.categories_id AS main_id, main.sort AS mainsorter, sub.header AS subheader, sub.categories_id AS sub_id, sub.sort AS subsorter, main.online AS mainonline, sub.online AS subonline FROM categories AS main, categories AS sub WHERE sub.parent=main.categories_id AND main.online = 'Y' ORDER BY mainsorter, subsorter";
$rsCatselect = mysql_query($query_rsCatselect, $sob) or die(mysql_error());
$row_rsCatselect = mysql_fetch_assoc($rsCatselect);
$totalRows_rsCatselect = mysql_num_rows($rsCatselect);
For the main categories I need another query where parent = 0.
I really would like to have something more clever than doing it by hand.
Fortunately there is this great extension called Menuwriter which is built and made to deal exactly with this kind of structure (dynamic menu - nested)
I would like to have an administrative tool to setup a menu more quickly. Also the menu structure from Data Assist for categories needs modification:
CREATE TABLE `productcategories` (
`CategoryID` int(11) NOT NULL auto_increment,
`CategoryName` varchar(50) NOT NULL,
PRIMARY KEY (`CategoryID`)
to something like:
`CategoryID` int(11) NOT NULL AUTO_INCREMENT,
`CategoryParent` int(8) NOT NULL,
`CategoryName` varchar(50) COLLATE utf8_unicode_ci NOT NULL,
) ENGINE=MyISAM DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci
Do you think this idea could be included in version 3 of DA?
Ian S
There is no reason why this can't be achieved with the current version of DA and CSS MenuWriter (I've done it in our latest CMS product)
Use DA to create your menu administration pages and CSS MenuWriter to dynamically create the menu on your front end pages.
Cheers
Ian
this_is_me
always room for improvement
Hi Ian, thank you for your reply,
the suggested database sql does not meet the parent requirement for categories. I don't want to have two tables like main and sub for categories. See my former mail.
How would be your steps to achieve it with the existing DA? Could you be kind enough to post a short description?
Thank you
