Adding a Date Range Search
Thread began 1/25/2012 9:49 am by mora398588 | Last modified 1/25/2012 10:34 am by Ian S | 497 views | 1 replies |
mora398588
I would like to add a search feature that would allow individuals to search my database by selecting a date range.
I have already used DA to create my page. I even had DA add search criteria to my results page. See my webpage at seminars.php
Back when I was creating my results page, I was given the option to search via date. I proceeded to have DA insert the feature as part of my search criteria. However, I was unable to make it work. When I tested the page, no results turned up. I noticed that the date format in the database was different from what I was inputting in the search box. I figured that there was some form of mismatch going on. So...I removed it.
I would like to add a data range search to my results page once again. I have attached my file for your review.
seminars.zip
Ian S
Check out this thread by Dave...
showthread.php?t=17864&highlight=Date+format
He wrote a little PHP function to convert the dd/mm/yyyy date tp Y-m-d which which will match the mySQL date format.
Cheers
Ian
