eCart https??
Thread begun 1/16/2012 12:01 am by david331670 | Last modified 1/24/2012 11:44 am by Jason Byrnes | 3068 views | 4 replies |
david331670
eCart https??
Happy New Year
I have somehow developed a problem over a few days and a few cart changes.
I don't know what I have done but it is confusing.
All the features work properly from the cart page, cart summary page, checkout page, confirm page and success page, on my resting server.
See screen shots attached.
If I use the actual online cart all appears ok to the cart summary page, once I checkout via the Https: secure server, the "Confirm Page" does not display the cart summary page properly.
It seems to have moved the associated numbers down 1 row. there is no "No of pages (20)
It displays the number of pages in the page price section as $20.00
I am blaming the checkout page for not passing on the correct info, yet it works correctly on my testing server.
The checkout get form data:
// WA eCart Get Form
if (isset($_POST["Checkout"])) {
$Spectrum_online->ClearCart();
$displayIndex = 0;
$runOnce = "run";
while (isset($_POST["ID_".($displayIndex)])) {
$ATC_AddIfIn = 0;
$ATC_RedirectIfIn = "";
$ATC_ID = "".$_POST["ID_".($displayIndex)] ."";
$ATC_Name = "".$_POST["Name_".($displayIndex)] ."";
$ATC_Description = "".$_POST["Description_".($displayIndex)] ."";
$ATC_Weight = "".$_POST["Weight_".($displayIndex)] ."";
$ATC_Quantity = "".$_POST["Quantity_".($displayIndex)] ."";
$ATC_Price = "".$_POST["Price_".($displayIndex)] ."";
$ATC_Thumbnail = "".$_POST["Thumbnail_".($displayIndex)] ."";
$ATC_Length = "".$_POST["Length_".($displayIndex)] ."";
$ATC_Height = "".$_POST["Height_".($displayIndex)] ."";
$ATC_Width = "".$_POST["Width_".($displayIndex)] ."";
$ATC_DescLg = "".$_POST["DescLg_".($displayIndex)] ."";
$ATC_Colour = "".$_POST["Colour_".($displayIndex)] ."";
$ATC_ItemCode = "".$_POST["ItemCode_".($displayIndex)] ."";
$ATC_ItemSize = "".$_POST["ItemSize_".($displayIndex)] ."";
$ATC_NoShip = "".$_POST["NoShip_".($displayIndex)] ."";
$ATC_job_id = "".$_POST["job_id_".($displayIndex)] ."";
$ATC_Pages = "".$_POST["Pages_".($displayIndex)] ."";
$ATC_PagePrice = "".$_POST["PagePrice_".($displayIndex)] ."";
if (is_numeric($ATC_Quantity) && $ATC_Quantity != 0) {
$Spectrum_online->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_ID, $ATC_Name, $ATC_Description, $ATC_Weight, $ATC_Quantity, $ATC_Price, $ATC_Thumbnail, $ATC_Length, $ATC_Height, $ATC_Width, $ATC_DescLg, $ATC_Colour, $ATC_ItemCode, $ATC_ItemSize, $ATC_NoShip, $ATC_job_id, $ATC_Pages, $ATC_PagePrice);
Can you help track down the error.
David
Do you have a url where I can see the problem? That might help me determine what is causing it.
I may have to look at the associated code as well. Are there any other session variables you are using that are stored outside of the shopping cart that might not be passed to the https server? The only issue with moving to an https server with a different domain is that session variables are lost. The code we have written will allow you to pass the cart session variables through a form post, but any additional session variables may have to be added manually. Most likely that is the issue, but I would like to take a look.
david331670
eCart
Thank you.
When all else fails... I replaced the new file an older version of the checkout page, late November date, and it just works. I can't easily see any difference but I will investigate to see what was missing, but there must have been something gone wrong. Finger must surely point at me.
Sorry for the trouble. I will try to find the error.
david331670
eCart checkout
It seems I have been to hasty with me fixing the problem.
I am sure it is between the Cart summary and the checkout page.
it is also happening with just the normal cart items for page quantity and page price, thats why I don't get it.
problem Url /Shop-Photobooks.php?pgx=54&pid=271&job_id=Photobook_1458796325489475
( a typical photobook )
same problem /Prices-Photobooks.php
Site url www.spectrumcolour.com.au
All the data is correctly passed on to the cart summary, its from cart summary to checkout to confirm page where the problem exists
What else can I send you?
Its only January and I'm confused.
Thanks David
