Wishlist addon, Banner Ads, Image upload on profile
Thread begun 1/12/2012 11:05 am by SPT | Last modified 1/16/2012 10:52 am by SPT | 2675 views | 4 replies |
SPT
Yeah I have a client wanting all of these and I am trying to pull together a quote for them.
Wishlist addon, Banner Ads (like google ads), Image upload on profile, sitemap ( I own Surveyor) .
Are these easy to add and will I be able to get instruction here or do I need to hire you guys or a webassist developer? I guess a primer ticket would be $100 would we be able to do it in the $100 allotted time?
FYI I do own almost every Webassist product if that helps me to make changes.
If anyone reading this wants to give me a quote (quickly) I will include it in my bid.
Thanks!
A wishlist is basically a way to store items from the cart into the database without purchasing them and then add them back to the cart from the wishlist. It involves creating the database and creating a page to display the wish list. This could be likely done in a premiere ticket time frame and is fairly complex for the average user to do on their own.
Banner Ads can be done many ways... do you want something like google ads, or do you actually want banner ads from google? The complexity of this depends on whether you are taking advantage of an existing banner ads service or if you are actually talking about creating an entire banner ad system. This could be quick or could be very time consuming depending on the details of how they want it to work and what they want it to work with.
Image upload on your profile is pretty simple and could be done in probably 15 minutes using Digital File Pro if you have experience with it. Go through the tutorials and you should be able to get that working on your own.
A simple sitemap can be built with surveyor and you could then edit it to look how you want it. This too I would suspect you could be successful with on your own.
SPT
Thanks Ray I will add that info to the bid.
Last question. This client says they may build up to 20,000 products.
Does the powerstore limit/bog down (not sure of the proper phrase) with that many products?
Seems like I have heard that a couple of years ago.
The most recent version should handle a large number of products well.
The bog down in previous version was actually associated to a large number of product options and not a large number of products. I think you should be ok.
SPT
Thanks,
Weight off of my shoulders!!!
