show multiple locations
Thread began 1/04/2012 3:45 am by medfordquiznos431182 | Last modified 1/04/2012 7:57 am by Jason Byrnes | 954 views | 1 replies |
Good morning I am not a great web designer I do it for fun and I bought this because it was suppose to be easy. I can not even get past the Show multiple options. the box is not even an options. I have watched the video, read the PDF, spent hours in the forum. So it must be simple I just can not find it is there a simple step by step. I would also like to know where or how to make my data set (yes I am that ignorant) I have about 100 locations saved in an excel spred sheet. I am using dreamweaver cs5. Thank you for all your help and I hope the new years treats you great.
Gene
All it takes for evil to thrive is for good people to do nothing
The Show Multiple checkbox will only be active if you have a recordset defined on your page.
That checkbox is used to tell pro maps to loop through the selected recordset. A recordset is a query using the SQL (Structured Query Language) language that returns a data set from a database.
Pro Maps for Google cannot use an Excel spread sheet as a data set. To use Dynamic Data in Pro Maps for Google, you will need to use a database.
If you do not have a database, you can enter the addresses manually into promaps by clicking the plus button to create a new address, filling in the information for street city state zip, then click the plus button again to create a new address.
if you are not familiar with databases, the database starter kit is a good place to start:
?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
also see the tutorials for setting up a testing server, configuring your dreamweaver site for dynamic development and setting up a database connection on the learning resources page:
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
