User Email Form
Thread begun 11/21/2011 9:55 pm by salaroche | Last modified 1/25/2012 1:42 am by h150477 | 5134 views | 13 replies |
cherry8723424721
User Email Form
Hi:
I have WA's Universal Email Extension installed in my DW CS5. Can UE help me make a form containing email fields that users can use to send emails to other users and to me?
Thank you for your attention
Dani Chankhour
Universal Email only sends email.
To create the Form you will need to purchase CSS Form Builder which also contains UE to help you build Contact Form which is one of the presets in CSS Form Builder.
cherry8723424721
OK. Thanks.
h150477
That seems a bit of a cheat
It should not be necessary for users of UE4 to purchase another product in order to code a form with which to use it. This is not mentioned as a pre-requisite in the sales documentation for UE4.
I find it surprising that the documentation provided with UE4 is missing large chunks of information that should be there for people to be able to use it.
I have used Web Assist products since 2004, and only now am I finding this mean attitude appearing.
It goes "Buy this product - its does this and this and this" - but when you do, you find that the paperwork is so designed that you have not much chance of using it without buying additional items or €50 a time support.
Why was it not pointed out before purchase that you cannot design a form to use with it unless you bought a WA forms designer? It did say that the form designer would help, but did not say bluntly as it does in the post above "You must buy ...."
Howard Walker
Ian S
"It should not be necessary for users of UE4 to purchase another product in order to code a form with which to use it. This is not mentioned as a pre-requisite in the sales documentation for UE4. "
Correct, which is why it is "not" necessary. Dreamweaver is perfectly capable of creating forms very easily without any additional extensions. UE aids with the more difficult task (for people who don't code) of creating the code to send the email using the contents of a form or recordset, doing exactly what it says on the tin (or the sales page in this case).
Cheers
Ian
Like Ian Says, you can use Dreamweaver to create your form.
Go to Insert -> Form for all of the DW Access points for creating a form.
the initial poster was asking if UE was capable of creating the form, the only Extension that we offer that is capable of creating a form is CSS Form Builder.
you can either create the form manually using the options available from the Insert -> Form menu or use CSS Form Builder to create the form for you.
h150477
Misread the post - sorry
Quote "the initial poster was asking if UE was capable of creating the form"
Having said that, I have tried the system with all details correctly filled in as far as I can see, and submitting the form does nothing. No error messages, no goto success page.
I allocated variables to the fields that looked likely. The form was not tested on line, but even so, it should generate some sort of output, even if it is only an error message.
It does create a lot of items in the bindings panel, but they never get any printable values.
The default form action is to submit to itself if no action is specified. This does happen, as it did generate error messages (now fixed by deleting the BOM) but then zilch.
Is this to be expected when tested in a browser on a local system?
I will upload it to another site and try it out there and see.
In the Universal Email behavior, what did you use for the trigger?
Send a copy of the page in a zip archive so I can examine the code please.
h150477
Trigger and zip
This post has been deleted.
the form tag is not complete:
<form class="wide1200">
this should have an ID, action and method:
<form action="" method="post" class="wide1200" id="form1">
