Delivery Fee based on presence of item in cart
Thread began 11/21/2011 12:10 pm by eric284736 | Last modified 11/22/2011 6:37 pm by eric284736 | 1401 views | 4 replies |
eric284736
I have a setup on the ecart where the customer chooses the zip code for the delivery destination.
Based on that zip code a session variable is set called FlowerFee. And on the add to cart I have a field FlowerOrder. If a flower item is added to the cart then the hidden value is 1.
During the checkout I want to add a shipping charge to pull that fee.
So in the charge panel the trigger should be:
Number of items with FlowerOrder of 1<0
AND If session variable exists: FlowerFee
Calculation
Based on column subtotal
Subtotal of column FlowerFee plus 0
I don't want the fee to be charged for EACH flower item they add to the cart. If the delivery fee is $20 to delivery to zip code 00000, then the total delivery charge is $20 whether 1 item is ordered or 5 items are ordered.
Is this correct?
thx
Eric
Dani Chankhour
I think your logic is correct.
I attached a screenshot of how the Charges rule should be set.
eric284736
Hi Dani,
Thanks! Could I get you to post a slightly larger screen shot because I can't see the info on this one very well.
thx!!
Eric
Dani Chankhour
Try the following URL:
eric284736
Perfect! Thanks Dani!
