Checkout Wizard Syntax Error
Thread begun 11/15/2011 7:08 pm by atstech | Last modified 11/22/2011 12:54 pm by atstech | 2967 views | 5 replies |
atstech
Windows 7, DW5.5, eCart 5, CSS Form Builder 2
When I run the checkout wizard, it creates the confirm, confirm_success, and checkout pages. However, I keep getting an error in my browser for line 33 - confirm.php see attached. I've tried clearing cache. I uninstalled and reinstalled the extentions and no luck. This did not start until after I removed UE 2 and installed SCC Form Builder 2.
That is the first issue,
The second question I have is that if I get the pages created correctly,... how do I open UE to alter my email settings?
in the download center page for CSS Form builder, there is a link to download the 2.0.1 Support Release 2 version of CSS Form builder, this issue is fixed in that version
make sure to uninstall the previous CSS Form Builder version from the extension manager before installing the new one.
to edit the email settings after it has been applied to the page, open the sever behavior panel and double click the universal email server behavior.
atstech
Thank you for the information. This did correct the problem. However, now I am noticing that the email is blank. The only way I can get the email to show up is if I click the Create a file for your email within UE. Prior to updating CSS Form Builder, eCart was sending the correct email nicely formatted with the order details. Now, even if I choose the Default file, the order details no longer appear. Just the generic email "Your Email Title Goes Here" All I am wanting to do is send the eCart order confirmation containing the order details and have it CC'd to another address. What am I missing?
atstech
also... I have Email Log enabled, it created the table email_log but is not populating with the email details.
Delete the existing checkout pages and recreate them using the wizard, the wizard will create the correct email message using the cart display manager to show the cart information.
if you edit the Universal Email behavior after the wizard creates the pages, do not select the Create page for the email option, that will erase the email created by the wizard
atstech
After doing so everything looks good now. Server Behaviors also show Universal Email 2 .. .instead of UE 1 earler. Emails seem to be coming through correctly. Thank you!
