Image Upload problem Live Server
Thread began 11/14/2011 9:02 am by Steve E | Last modified 11/14/2011 10:41 am by Jason Byrnes | 1777 views | 7 replies |
Steve E
Hi
I have a problem with images being uploaded to my server, I am testing the update images page which works perfectly on my local machine.
I have file permissions set to 755 (I have also tried 775 and 777) for the directory. The file name displays in the dB and the location prefix is added correctly, but no upload is taking place.
We are hosted on a VPS Cloud hosted solution, any ideas what could be causing this, I have tried this several times to no avail, your help would be greatly apreciated.
I have attached the file FYI
Thanks in advance
to troubleshoot, edit this line:
$WA_redirectURL = "images_Detail.php?imageID=".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"") ."";
$WA_redirectURL = " ";
so that no redirect occurs
add this code at line 1:
error_reporting
(E_ALL);
to turn error reporting on
and add this code after the <body> tag to show the upload results:
<?php echo WA_DFP_AllUploadsDebug(); ?>
post back the info these changes write to the screen after testing the upload.
Steve E
Edited for security
hmmmmm, change:
<pre><?php var_dump($_FILES); ?></pre>
and post back the results after testing upload again.
Steve E
Edited for security
Steve E
This page is also failing to update on my local server as well as my product update page which uses a different directory? They were all working a couple of weeks ago?
Steve E
Hi Jason
I have re applied my original template and every thing seems to be ok with this now. I must of moved some code when I tweaked the admin pages prior to upload sorry to waist your time.
OK, glad to hear it is working.
