Product Options Administrative Tutorial?
Thread begun 11/03/2011 6:49 am by Justin@AdventDesign | Last modified 11/04/2011 7:13 am by Jason Byrnes | 5647 views | 12 replies |
Justin@AdventDesign
Working with eCart using Product Options for the first time. I've been through the "Product Options with eCart" tutorial, and believe everything there is set up correctly. Is there a tutorial or guide for setting up the administrative pages properly in order to add product options to individual products?
With 4 different tables to deal with (products, productoptions, options, optiongroups) I'm having trouble getting my head around how to tie it all together so my customer can manage it with administrative pages.
Justin@AdventDesign
Further clarification
I should clarify what I need to do. I don't, at this point, need the client to be able to add options groups or even options themselves, as these are constant. I do, however, need to be able to select the proper productoptions from the dataassist created insert and update pages for the products table.
In other words, while they are creating or updating product "A", they should be able to check or uncheck available material (or 'color' as it was in the options tutorial). I can create a recordset pulling the proper options based on the objectgroup ID, but I get lost as to how to get all that to write or delete the proper listings in the productoptions table while at the same time the page is writing to the products table.
Hoping since you had such a great tutorial on adding product options to the cart side, you have one as well for the admin side of options, but I don't see it.
on the product insert / update pages, you would need to use the Data Assist manage relational table behavior.
you would create a recordset to return the available options.
add a checkbox to the page. Set the value of the cehckbox to use the optionID column from the option recordset, set the label for the check box to use the option name.
Now add a repeat region around the check box so it will loop through the option recordset to show all options.
*1- If this is the update page we need to create a binding in Dreamweaver before proceeding. Open the results page for the products table in the web browser, click on the update button for any product to open the update page, notice the address in the browser has a querystring variable, it will look something like this:
update?productID=3
Copy the name of the Querysting variable, in my example above it is "productID", then go to the bindings panel in Dreamweaver, click the plus button and select URL Variable, and paste the name that was copied from the browser. This will create a new databinding for the Query String variable used to load the product into the update page*
*-2 For the insert page, we need to find the name of the session that will be created when the product is inserted, go to the Server behaviors panel and double click the insert record behavior. In the session variable section, make note of the Save As setting, this is the name of the session that will be created.
cancel out of the insert record behavior, and go to the bindings tab, expand the session collection and make sure a session binding with the name from the save as setting in the insert record behavior exists*
Next add the Manage Relational Table behavior.
On the first step, set the relational table to be the productsoptions table
On the Second Step, the "Main table Join" column is the productD column, set the data type to numeric.
- On the Insert page, click the lightning bolt next to Key value and select the Session variable that is created by the insert record behavior (refer to *-2 above)
- On the update page click the lightning bolt next to Key value and select the URL Variable used to populate the update page (refer to *-1 above)
On the Third step, set the foreign key column to the OptionID, for Options From Field, select the Repeating checkbox. on the forth step, you can review the settings and click finish
Justin@AdventDesign
Wow. The cart side was easier than I thought so hopefully the admin side will be too! I'll give it a shot. Thanks for the info. I'd urge you to make this into a full blown tutorial at some point, as anyone incorporating options will need this every bit as much as the cart integration.
Justin@AdventDesign
Almost got it
Great instructions Jason. Everything went exactly as you described and appeared to be correct. However, after completing all the steps I get the following error trying to load the update page:
Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING in /Applications/XAMPP/xamppfiles/htdocs/beta/00_Aveo/sitecontrol/tbProducts_Update.php on line 269
Line 269 is:
$WA_joinLoopedField = "<?php echo $row_rsMaterialoptions['OptionID']; ?>";
Which is right in the midst of the Relational Table stuff here:
// WA DataAssist Manage Relational Table 1
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_arrayOrFieldList = 1;
$WA_loopedField = "WADA_RepeatID_OptionID";
$WA_connection = $adventcms;
$WA_table = "productoptions";
$WA_redirectURL = "";
$WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_masterKeyField = "ProductID";
$WA_masterKeyType = "none,none,NULL";
$WA_masterKeyValue = "".$_GET['id'] ."";
$WA_masterKeyComp = "=";
$WA_joinedKeyField = "OptionID";
$WA_joinedKeyType = "none,none,NULL";
$WA_joinedKeyComp = "=";
$WA_fieldNamesStr = "ProductID|OptionID";
$WA_columnTypesStr = "none,none,NULL|none,none,NULL";
$WA_appliedString = "";
$WA_appliedList = array();
$WA_valuesList = array();
$WA_connectionDB = $database_adventcms;
if ($WA_arrayOrFieldList == 0) {
$WA_loopedValues = $_POST[$WA_joinLoopedField];
for ($v=0; $v<sizeof($WA_loopedValues); $v++) {
$WA_fieldValues = "^MASTERID^" . "|" . "^JOINID^";
$WA_valuesList[] = array($WA_loopedValues[$v], $WA_fieldValues);
$WA_appliedString .= "^" . $WA_loopedValues[$v] . "^";
$WA_appliedList[] = $WA_loopedValues[$v];
else if ($WA_arrayOrFieldList == 1) {
$WA_mrtLoopCounter = 0;
while (WA_AB_checkLoopedFieldsExist(array($WA_loopedField), $WA_mrtLoopCounter)) {
if (WA_AB_checkLoopedFieldsNotBlank(array($WA_joinLoopedField), $WA_mrtLoopCounter) && WA_AB_getLoopedFieldValue($WA_loopedField, $WA_mrtLoopCounter) == WA_AB_getLoopedFieldValue($WA_joinLoopedField, $WA_mrtLoopCounter)) {
$WA_valuesList[] = array(WA_AB_getLoopedFieldValue($WA_loopedField, $WA_mrtLoopCounter), $WA_fieldValues);
$WA_appliedString .= "^" . WA_AB_getLoopedFieldValue($WA_loopedField, $WA_mrtLoopCounter) . "^";
$WA_appliedList[] = WA_AB_getLoopedFieldValue($WA_loopedField, $WA_mrtLoopCounter);
$WA_mrtLoopCounter++;
WA_AB_doManageRelationalTable($WA_valuesList, $WA_appliedString, $WA_appliedList, $WA_connection, $WA_table, $WA_masterKeyField, $WA_masterKeyType, $WA_masterKeyValue, $WA_masterKeyComp, $WA_joinedKeyField, $WA_joinedKeyType, $WA_joinedKeyComp, $WA_fieldNamesStr, $WA_columnTypesStr);
if ($WA_redirectURL != "") {
Justin@AdventDesign
Same error on the same line after completing the insert page as well.
it looks like you selected the OptionID column from the rsMaterialoptions recordset in step 3 of the manage relational table behavior instead of the checkbox in the repeat region.
double check that the settings in the manage relational table on the update page are the same as for the insert page.
the only difference on the update page will be using the URL Variable for the Main table Join Key value.
nowhere do you use a recordset value in the manage relational table behavior.
Justin@AdventDesign
Wow something went haywire
I set the key column to the OptionID as suggested. The options from pull menu only gave me one option, which was a bunch of PHP code.
I went back in to the Manage Relational Table dialog to check your suggestion, and I got several pop warnings of errors including "THe column name "false' was not found." and "The column name "".((isset($POST["WADAInsertRecordID"....etc., was not found."
Then once into the dialog, the selections were all goofy.Clearly something went wrong. I'm starting over with the original insert and update posts from scratch. Will let you know what happens.
Justin@AdventDesign
Ran through from the start, same problem
Ran through from the beginning, same problem...
I've attached progressive screen shots showing the settings I'm entering and what I am seeing for your information.
Here's what I did per your steps:
DONE - named rsMaterialoptions
DONE - and confirmed it was loading properly
DONE - all the proper rows repeat properly with the proper value
update?productID=3
DONE - mine is actually 'id', I'm using almost all the sample options database provided by web assist, but I'm tying it to my own existing master product table rather than the 'products' one provided.
DONE
DONE - update page still works properly at this point.
DONE
DONE, set to id as noted above
DONE - I'm only given one option for hte options from field, but it appears to be PHP code that fits your description (see screen shot attached)
When I get done, I save the page and attempt to browse to the update from the results page and get the error I noted above. I then go back to the Manage Relational Table behavior I get a bunch of errors which I have on the screen capture.
