Universal Email Bug
Thread begun 10/27/2011 11:06 am by dlovas275157 | Last modified 11/30/2011 11:18 am by Jason Byrnes | 3751 views | 6 replies |
dlovas275157
Universal Email Bug
Anytime I edit an existing Universal Email SB and proceed to edit the template, once I finish editing the template via DW Mode and return to the remaining UE Dialog, all the details I have already entered in are wiped-out. I have to re-enter.
Then, sometimes after I re-enter all the info, the Universal Email SB is not edited, instead a second UE SB is added next to the original. So I then have 2 UE SB's in the server behaviors panel - which neither work correctly.
Using DW 5
Mac OSX
CSS Form Builder 2.0.0
What can I do to fix this?
wbrooks199805
Having the same issue
Also, universal email disappears in behaviors so I can't edit it there either.
Ian S
I get this sometimes aswell.
I seem to find it happens more if I chose File > Save after editing the email contents within Dreamweaver. If I use the Cmd + S shortcut it seems better!
I started to take the approach of designing the email layout separately and then copying the code into UE and then applying the dynamic tags as necessary.
Ian
wbrooks199805
any news?
I don't see this in my support.
I have created a new one for you, should be there now.
